enblethen
Jun 08, 2018Nomad
The second one is not making contact. It could be bad control, bad connections, or bad contacts.
The 6 volt reading could be missed wiring on batteries if you have two six volt batteries. Common for Fleetwood to use two six volt batteries for the coach system. If you have 6 volter, the positive of one goes to the negative of the other. Then positive of the empty one goes to disconnect while the negative of the other goes to ground.
Yes it could be a bad connection, but on either the positive or negative.
