Miked9606
Jun 08, 2018Explorer
enblethen wrote:
The second one is not making contact. It could be bad control, bad connections, or bad contacts.
The 6 volt reading could be missed wiring on batteries if you have two six volt batteries. Common for Fleetwood to use two six volt batteries for the coach system. If you have 6 volter, the positive of one goes to the negative of the other. Then positive of the empty one goes to disconnect while the negative of the other goes to ground.
Yes it could be a bad connection, but on either the positive or negative.
Further testing. The second one must be my aux. turned aux switch in and have same on right post now. Also took ground off of chassis and battery and cleaned it up. Reading 11.5 on meter when I go from chassis ground to bat +. Still no lights or start. Going to pull + and clean that. Any other ideas?
