RLS7201
Apr 08, 2017Explorer II
If you do have a 460 engine then you have an E4OD transmission.
Those older Ford transmissions would take off in second when the shift lever was in "2". That would explain why you was able to limp to the gas station. Now you need to find the reason why 1st gear is not working properly. Your torque converter is probably OK. Else wise, you wouldn't have been able to move in 2nd gear.
Richard
Richard
