Cousin_Eddie93
Jul 06, 2016Explorer
jeffengle wrote:
take the lines off at the master cyl.& plug the outlet ports. you should have a full hard pedal. than one by one hook the lines & checking the pedal. when you get a spongy pedal, you know which end is the problem, you can do this for the length of the system. most likely air in the system, a good pressure bleeder should work. jeff
Agreed, I had a 72 ford Galaxie that would never have enough brake pressure unless the lines and cylinder were completely air free.
