KCFDCapt
Jul 15, 2017Explorer
I have used my TIG torch to heat broken exhaust bolts. Set the amps to 150 and put the arc on the bolt only. This will heat the bolt and help break the rust free. It will draw the temper from the bolt so you won't have to use all your vocabulary when removing the broken bolt.
