wolfe10
May 28, 2015Explorer
Timing chain on Cummins C????
Most likely is a weak fuel shut-off solenoid. The replacement from Cummins is more robust. Short term, you should be able to wire it in the open position, but will have to unwire it to stop the engine.
Here is a very good description with pictures: http://www.beamalarm.com/Documents/fuel_shut_off_solenoid_replacement.html
38,763 PostsLatest Activity: Dec 05, 2025
