Tyler0215
Feb 07, 2020Explorer
Why was the rf tire at 125psi? That's to much for a front tire.
If the rear springs are sagging, you should probably get a new set of leaf springs. Weight he MH , front and rear axles, loaded and ready to go and take the weights with you to the spring shop. They can install the correct springs.
Also with your loaded weights you can adjust the air pressure in the tires to the proper psi.
38,773 PostsLatest Activity: Apr 25, 2026
