RLS7201
Feb 07, 2020Explorer II
RustyMacIntosh wrote:
I dont know how the front tire was so high, I had tires put on it in Oct, my I'm been watching the rears, I never paid much attention to the front
We are going to weigh the MH this afternoon
If your coach has a Ford F53 chassis, your tires are 235/85R16. In single tire configuration, your tires will carry 3042 lbs ea @ 80 psi and 2773 @ 80 psi in dual tire configuration. That's 6,084 lbs of capacity for your front tires and 11,092 lbs of capacity for your rear tires. You coach as built has a 6000 lb front axle and a 11,000 rear axle. So set your tires @ 80 psi. I can guarantee you will be running over weight on your rear axle any time you fill your 100 gallon fresh water tank.
Richard
38,773 PostsLatest Activity: Apr 25, 2026
