Cousin_Eddy1
May 31, 2017Explorer
There is an adjustable switch under the floor, under the steering column. You have to remove a sheet metal panel in the drivers front wheel well to access it. Its like a mini tie rod. It will be intuitive how to adjust it once you see it. It comes loose and looses its adjustment. I think the oldusedbear may have a photo of it.
In the mean time, put pressure on the column shifter toward neutral, with out going into neutral, when backing up. That usually will disengage the AP.
38,769 PostsLatest Activity: Dec 31, 2014
