monaw81's avatar
monaw81
95 Dodge saratoga customizing and mods
Purchased a 95 Dodge Ram 3500 coachmen Saratoga (I believe) van- looking to make some modifications and have had no luck in googling possibilities. Do you own a dodge class b that you've customized or a similar model to mine and you are converting?
I am mostly looking into removing partition walls in the back, raising the bed frame to add storage and some other ideas- maybe. Just hoping for inspiration before I consider digging in.
  • Not a shabby idea :) we'd run into clearance issues. I think I am going to build the diy seat bed tomorrow and then try the pvc hammock next. This way we have a few more months of testing it out to make sure everything's good to go :)
  • monaw81 wrote:
    Stan- mine is just like you described with the two beds on each side running length wise) that have the back rest that folds over and meets together In the aisle creating a large bed. I was aware at the time that there would be a few adjustments made and arguably we are fine leaving it how it is. That being said, we got a great deal on the van and fell in love with it (after our lemon inspectors checked it out) and we plan to use a tent, van and I am creating the collapsible bed to lay on top of the front passenger seat that turns around and faces the behind seat. I just wanted to come up with an easier, more long term solution since we will be on the road a long time. I am also looking into the front seat hammock idea as well made from pvc pipe. For the most part we are happy to tent together and use the van or a combination but I have to also plan on torrential downpours that might force us all to sleep inside. Yes, we can make it work. I was just hopeful for creating something slightly more permanent and versitle :)
    Hi,
    I have a chance to buy a 1996 coachmen Saratoga.It does not have the couches where the backrest flip to the center of the aisle mechanically like yours. My question to you is when the couches are in the normal position for sitting can you lay down on either one of them and have room to sleep? It doesn't look like there's much room with the back rest in place. I'm just guessing but it looks like that one of the couches has to be folded down in order to sleep on one of them only.
    Also, I saw a picture of only one of the couches folded down and it doesn't look like there is too much room to walk in the aisle to get to the bathroom, is that correct? If you had a choice would you stay with your existing couches or would you go to the later models where the backrests are not attached to the couch itself.
    I'm going to look at the 96 model tomorrow so I have to make a decision. Any feedback for you would be appreciated.
