Kenmartin1's avatar
Kenmartin1
96 460 f53 rv engine hose diagram question.
96 460 f53 rv hose diagram question. Does anyone have a diagram of hoses an vacuum hoses? Previous owner left a few loose. I have a hose coming off of the oil intake pipe that is open on the end, just laying loose, and it is about 1/2 5/8 inch I.d. I also have a small plastic vacuum tube which was probably eaten by mice, laying in the lest rear intake, can't find where it goes either. Thanks, ken
    97 Coachmen 460 F-53 has the hose from oil fill tube going to the back side of the air filter housing.
  • You might go over to IRV2 forum. There is a member there (subford) that probably has a diagram of what you need, if he does he will gladly post it for you.
  • Can't help but a Ford dealer might be able to. Their parts diagrams should show what you want.
