enblethen
Jan 10, 2016Nomad
Double check owners manual for fuses. Most rigs have different fuses for turn signals and flashers.
Looked at wiring diagram. shows two fuses fuse 7 hot in run and fuse 9 which is also brake lights. Do the brake lights work?
Everything goes through the multi-function switch. If brake lights work then sounds like the switch.
Switch for four ways is where power separates the two fuse inputs.
38,766 PostsLatest Activity: Jan 10, 2026
