MountainAir05
Jan 22, 2021Explorer II
Ohm the two cables to ground. If one is 0 ohms then that one is to ground and if the other one is more ohms then to the 12 volts. Or run a trace if you have that tester and see where they go, and go from there.
Can't help on the converter. By any chance are the wires there White.
