Any ideas would be appreciated. When I hook up to city water supply water pressure seems normal. When running on the pump pressure is a light trickle. I installed a new shurflo water pump with straine...
On some systems there is a valve that needs to be closed so that pumped water does not recirculate.
I had one like that, and the water would pump out of the pump, but it would just run back into the water tank through this valve.
The purpose of the valve was to allow filling the tank from the connected shore hose if the valve was open. If the valve was closed, outside shore water would just run to the taps.
