68ragtop's avatar
68ragtop
98 rambler interior no interior lights
Hi new here having problems with my coach, lost my interior lights have power in main box the 50amp wire but no power to my 15 amp fuses in bedroom before I try and trace wire to back was wondering if anyone had this problem? so I have power coming out of coach batterys runs to front circuit board but no power on 15 amp fuses in bedroom. is there a juction box between front board and fuse box in bedroom?
TIA
    TIA
    As said, check the battery sw. near the front door first. If on, pull it and check for voltage on both sides of the sw. or disconnect and check for continuity with an ohmmeter.
  • Ever see arc welding ?
    That IS a controlled short circuit
    That is what a short circuit does it melts wire, it blows fuses, it burns things
    You have an OPEN circuit, an interruption in the delivery of power
  • ok I have power up to front circuit board/fuse board from the house batteries my other fuse box in the back bedroom I have power there for the ac but not for the line of fuses that control the interior lights, so I going to follow bed room line to find short or if there is a junction block in between
  • Ivylog's avatar
    Ivylog
    Explorer III
    Turn the house battery disconnect switch back on by the front door.
  • what front circuit board? sounds like that is on the chassis/starting battery
    there should be a direct line between the batteries and the DC power center
    aka 12v fuses
    you have blown the battery fuse for the DC power center or the have a bad connection somewhere
