lc0338
Jun 27, 2015Explorer
Before the shop that found the dragging starter (when hot) problem another shop had told me when you have the problem if you can pour water on the injector pump to cool it off. If it starts then, that points to the injector pump. You might "if you have time and want to" take a water spray bottle and crawl under and spray the starter to cool it down, then try it. Best way is to take it to someone who can test/measure the cranking RPM when it is hot.
38,774 PostsLatest Activity: Apr 26, 2026
