gbopp
Nov 02, 2015Explorer
willi4nd wrote:jsmart wrote:
We have an older class A, what would make the pipes brittle like the op describes.
Chlorine breaks down PEX over time, causing it to become brittle.
Sunlight also breaks it down but in the case of RV's this is most likely not the cause
Maybe the builder received a bad lot of plastic pipe? Usually very little chlorine used to sanitize the water system.
And, the amount in a municipal water system shouldn't harm the plastic pipe. JMO
