MrLugs
Nov 03, 2015Explorer
Old-Biscuit wrote:
Welcome......
Plumbing project in an RV.......that can be a challenge
PEX is a good replacement for that 'Thermoplastic Material' used in your 2000 Southwind.
Just make sure that those 'bends' are not too tight and are secured so that they don't rub on corners/edges.
And I like paragraphs when posts are long, involved. Does make for better presentation of info.
I'm still figuring things out as I go. What I found works in some areas are the plastic 90 degree bracket that you snap the pipe into, it gives it an easy bend and has a hole to screw it in place.
In other areas zip ties and even some foam pipe insulation works well.
