dougrainer
Feb 19, 2022Nomad
larry cad wrote:dougrainer wrote:
I double checked to make sure. That area of burn was NOT caused by the actual exterior Aqua Hot unit or its components. That ribbon cable is ONLY for the Interior components of the Aqua Hot system. The various fan motors for the radiators. So, if that harness gets pinched or someone attempts to troubleshoot without knowing which wires do what, that overload would go back to the board and melt it. But none of those would cause a clicking sound. Doug
Everything you see is totally factory wiring. And when you consider that Hydrohot replaced everything in warranty you can be sure it was factory responsibility.
Fairly new Fleetwood Discovery.
You misunderstood my comments. YES, the wiring going to the inside radiators and blower fans is Aqua Hot. What I was stating is, the burn failure was caused by Fleetwood and the install. Doug
I happened to be there when this was discovered and was able to take pictures. My fingerprints are not on this one! :B
