pnichols
Feb 20, 2015Explorer II
Outstanding retrofit on your Smart Car's tire up-sizing! Do you get any tire rubbing of the wheel wells or suspension components? However, why does it still look like it has lower ground clearance in the front than the back?
Out in the desert, we need the best possible ground clearance at both ends. The ground clearance you've created in the back looks quite adequate for our needs. Having the same tire size all around is a BIG plus.
38,763 PostsLatest Activity: Dec 05, 2025
