BULLETLS1
Sep 06, 2013Explorer
Thanks DAVEINET for clarifying the pic!
thank you all for the comments, yes it had a odd brake light,
I found a diameter cutting tool, and a milling machine, after much consideration because the cluster connector was in the way of the cutout, I will need to find a 12 pole male-female connector, but that's easy, the rear of the cluster has a plastic flexible printed circuit that will be done with regular wires individually.
tried to keep the tacho face away from the glass just a fraction away.
glued with black silicon.
hope you like it!
If I could cram a 737 hardball cockpit in my RV I'll be a happy man! HAHAHA!
hope you like it!
38,782 PostsLatest Activity: Sep 10, 2026
