Gjac
Jun 12, 2014Explorer III
Daveinet wrote:Interesting, mine is a 1995 33 ft 11 ft 6 in high and weighs about 15,000 fully loaded. I did not think the weight would be that much difference. 8000 lbs is a lot of weight increase, but I guess when you look at the whetted surface area increase of the newer, higher, wider mh's plus slides the weight adds up quickly and it is still HP to weight that affect performance and mpg's.
I'm almost 32 feet. Weight is 13580 fully loaded.Gjac wrote:They are significantly more efficient, its just that they are installed in units that are much taller and about 8K lbs heavier. Most the old 454 are running in coaches that are 16K lbs on lower profile chassis. The 6 speed does not help mileage, but just optimizes engine speed for best use of available power. In high gear, the engine RPM is still nearly the same, regardless of if you have a 4 speed or a 6 speed. The difference is that when you ask for more power, it will shift sooner, so the engine is turning the optimum RPM for the needed power. You also have a lower first gear.
I am surprised also that the newer 8.1's and V-10's don't do better than the older motors. Most seem to report 7-7.5 mpgs on on the newer MH's with 5 & 6 speed transmissions, while 8-8.5 mpg seems to be the norm for a 454 TBI with a 4 speed transmission for the same length MH. Maybe more HP uses more fuel? Weight of stuff inside more slide outs?
38,782 PostsLatest Activity: Sep 10, 2026
