DiploStrat
Aug 30, 2014Explorer
Tiger owners are nothing if not proud of their beasts.
Because of my work, I have driven dirt for most of my life and our Tiger, Ndeke Luka, handles wonderfully on dirt. Ndeke Luka
If you stick with a 4x2, then I like the following:
-- Mild lift to get the underpinnings out of the way and improve angles of attack and departure. Something like this: Lift Kit
-- The largest tires you can get away with for ground clearance and cushioning.
-- The softest springs that will handle the weight of you truck, to absorb shock and vibration without passing it through to the frame and passengers.
-- The longest wheel travel you can get to avoid bottoming. (Much the same reason.)
-- The biggest, stiffest shocks you can mount to limit fading and control sway.
-- Limited slip or locking differential for the soft stuff.
You may find that the folk who post here will have information to share: Vans at EXPO Portal Forum
Safe travels!
Safe travels!
38,782 PostsLatest Activity: Sep 10, 2026
