Tis a little information if you have a problem with your ABS light not going off. The code did not pin point this problem, This was found with a Monaco tech helping the tech on the MH, all sensors wor...
Well I have found it is very easy to lockup your brake if you just need to stop in time for a red light, if it catches you off guard. I don't like the thought putting out 3 or 4 hundred dollars for a tire. Also I am thinking about selling so I don't think it would sale with the ABS light on. Roy
