Have a new 2014 Winnebago Sigheseer. Recently I've noticed that when I have the fridge mode set to Auto(AU), propane turned on, and then disconnect from AC, the fridge doesn't switch over to propane a...
If it does NOT light on LP due to a LP supply problem you will get a check or error code on the refer and the OP does not state he gets any such code. Doug
