VA-Apraisr
Sep 04, 2018Explorer II
Follow up: Took cover off and cleaned coils front/rear with simple green. I notice the only drain hole in the metal pan was in the middle of the pan and was clear of debris. Is this the only drain hole? If camper is on slight angle, does the water simply go over the 1/4 height of the pan as it fills up? Maybe another hole or two in the pan beneath the fan area?
