A different issue on same system. Mine if functioning correctly except I'm tripping a 30 amp breaker after running for a while on warm days. After reset I still trip even with just fan running. I also am noticing that the power meter is spinning pretty fast. I do notice on the motor it does say " 3.1 A " and I'm believing that is stating that this motor is using 3.1 amp while running. I'm thinking that there may be some maintenance that I can try and do to reduce the load. I did notice the oil applicators (like those in my hot water head motors) and will lubricate them on a regular basis now. I have pulled the motor and am going to run amp usage bench tests. Just looking for any advice or information I can get.
