Jim
Jun 19, 2013Explorer
A couple things come to mind. If you're in the desert southwest, with relentless sun beating down on the A/Cs, AND the sun hitting the wall of a cabinet where your Circuit breakers are, then it's possible you need to service the A/Cs up above to ensure they are all clean, fins are straight, and the insulation is in place. And, you might open the cabinet where the CBs are (if they are in a cabinet where the sun will hit the outside wall) in order to allow them to cool.
And of course, as mentioned, check that the voltage to them isn't too low.
38,782 PostsLatest Activity: Sep 20, 2026
