Have a 2003 36' Gulfstream Ultra Supreme. Never had issues with A/C's b4 & don't know anything about them? I do have an issue with the front unit now.Unit works as intended when controlled by thermost...
The a/c works great with either power source? The problem is when unit is in the OFF position and you plug in or crank Genny, the front unit, ONLY; tries to come on for 2 mins. and cycles that way; with NO air coming from vent; off for 20 mins. & Does those cycles as long as power is coming to it? No matter which source? I can go in & operate with thermostat ON & control thru temps & works just fine with air coming from vents & all?
