cableguy574 wrote:
What tricks does anyone to keep a Rv cool in the summer, these past few days have been low 90s. I have basement are and run the generator to keep it going down the road. but it seems just cant keep up the hot days, 95 outside 85 inside. any thoughts
sure...
1). if you have slides bring them in during the day. less sq ft to cool means more efficient cooling.
2). get a couple of fans and move the air around.
3). if you have a MH get thee to a big box store a get a roll or two of reflective window foil and cut a piece to fit the inside of the windshield. the windshield acts as a radiator pumping heat into the RV. this will darken the interior but the inside temp will drop 10-15 degrees within 30-minutes.
window foil
