dougrainer
Jan 25, 2022Nomad
Sandia Man wrote:
I imagine there was an option for a second AC, many dealers in cooler climates will order them with just a single AC. There are a lot of variables involved making it difficult to state if a single unit will suffice in that particular rig, but we had a single AC in a 32' RV and it could keep up with 90+ degree although it would run pretty much non-stop during the heat of the day. I have seen many rigs over 30' with only a single AC, if you are often RVing in those temps you can add a second unit although RV AC units are a bit difficult to come by at the moment due to pandemic.
I should have mentioned about the northern states dealers. Yes, it isw common for cooler climate dealers to go with 1 AC. BUT, what happens when those customers travel south? If you have cooler summer temps then 1 AC may be enough. But the poster stated 90 degree temps. THAT is what you need to respond to. Doug
38,782 PostsLatest Activity: Jan 05, 2026
