lryrob9301
Jul 06, 2015Explorer
To recharge that system it is best to pull a vacuum on the system through the front set of both ports for over 1 hour. Then close off the valves on the A/C gauges and let it set for 1/2 hour, note if the vacuum indicated on the gauges starts to bleed off. If so you have a leak, if not then charge the system with 2.2 lbs. of Freon that has dye in it. Your vent temp should be around 50 degrees with ambient air temp of 80 degrees and the coach not being in direct sunlight.
38,758 PostsLatest Activity: Nov 02, 2025
