Dachristianman wrote:
Even after cleaning the condenser, it appears that the output temperature gets colder on the "low cool" setting than on high. That tells me that it may be a bit low on R22 but since I don't have the gauges to service R22, I'll just run it on low cool and hope for the best.
That is NOT a valid test and really means nothing. ALL AC systems will get colder air on a lo fan setting because the air going thru the evaporator is moving SLOWER and has more time to "absorb" the cold air on the evaporator coil/fins as it flow thru. The ONLY valid test for a RV AC roof top system charge is a AMP DRAW reading of the compressor corrected for outside ambient temp. Doug
