dougrainer
May 18, 2016Nomad
LongWeekends wrote:
A quick update. Thanks for your help! I unplugged each black and gray wire at the front AC unit and cleaned the connectors on all sides. The AC has been cycling off and on perfectly all day since then. I'm not going to jinx myself and say it is fixed but it is working properly for now.
Thanks for the help. I would have never gone down that path and figured it out!
IF you saw corrosion on the plugs, cleaning will not do for a long term fix. Replace those modular plugs if they are corroded. BTW, that phone type cable is NOT a Phone cable. It is called a communication cable and the plugs are wired BACKWARDS from a phone cable. You cannot use a phone cable with plugs already on the cable. Doug
