I plugged the motorhome into shore power. Naturally of course the A/C unit is not putting out cold air. The rear one won't even come on. Even though the switches are set to front so that they both...
Both fan and compressor capacitors checked or replaced, as it can't start with a bad capacitor and a common occurance? Any fans froze and giving it a spin will get it going? Then taking it apart and applying some lube might keep it going for a long time. With no cooling, you could have lost some refrigerant and a tech might solder in some fittings and charge it back up reasonable. In fact, it might pay in the long run, to have a tech look into the situation.
