shaneperch
May 07, 2013Explorer
A/C units
I plugged the motorhome into shore power. Naturally of course the A/C unit is not putting out cold air. The rear one won't even come on. Even though the switches are set to front so that they both...
tropical36 wrote:You'd have to find one awfully hungry tech to get him involved in anything like this because its a no win situation for him. He simply can't charge enough to make it worthwhile.
Both fan and compressor capacitors checked or replaced, as it can't start with a bad capacitor and a common occurance?
Any fans froze and giving it a spin will get it going? Then taking it apart and applying some lube might keep it going for a long time.
With no cooling, you could have lost some refrigerant and a tech might solder in some fittings and charge it back up reasonable.
In fact, it might pay in the long run, to have a tech look into the situation.
