I plugged the motorhome into shore power. Naturally of course the A/C unit is not putting out cold air. The rear one won't even come on. Even though the switches are set to front so that they both...
Your rig is probably wired for 30 amp service so you can only run one A/C at a time. In my rig I have 2 thermostats one is in the hall and is for the furnace and front A/C. The other is in the bed room and is only for the bedroom A/C. So just try running 1 A/C at a time and see if one or both work but with 30 AMP only one at a time will work.
