dougrainer
Jul 25, 2020Nomad
B.B.Upch wrote:
Ok so my lights are working & my micro wave is working but my ac is still not coming on.. also my slide out is not working but not sure that is caused by same problem.. I only have 1 house battery on right now. Not sure that matters. Its been a while since i used the slide out
You slide out does not use any 120 volts to operate. It is 12 volt. At this point, you are just wasting time until you remove the 120 Breaker panel cover and actually use a voltmeter to see if ALL the 120 breakers have 120 volts. Your M/W "may" appear to be operating because it may be on an Inverter Circuit and your Inverter is ON. I am leaning towards a burnt out transfer box because you stated you have your 50 amp coach on adapted 50 to 30 and doing that over time will cause a Transfer box to heat up and burn out the contacs. Once you test the breakers in the 120 breaker panel, that will narrow down if your Transfer box is bad. Doug
