- allbrandautoExplorereasy way to tell if its the ac not getting cold is try to locate the two refridgerant lines going to dash the bigger line is suction line it should feel cold to the touch if it is you do have a temp. blend problem
- AL49erExplorerCan some one tell em where this ac water valve is on my 2004 kontry star Nemar?
mc.cc wrote:
dougrainer wrote:
mc.cc wrote:
I have discovered that I am having a problem with the electronic water valve on mine. It is a two hose system. I blocked the hose that exits from the valve going to the heater core with a pair of vice grips. It works and I am getting cold air now. If I block the upper hose to the heater core too, will this create pressure in the heater core causing potential problems, or is it OK to do this?
NO, it will not create any problems. Think about it. What happens when the water valve functions correctly? It blocks the water flow off completely. Why did you not block the inlet hose first,instead ???? Doug
Thanks Doug! Which is the inlet hose? On the valve there is an arrow that I think indicates which way the coolant is flowing. I blocked the hose as it exits the valve going to the core. There is an upper hose connected to the core that I think is going back to the engine. This is the hose that I was referring to when I asked if I could potentially block both hoses. A new electronic valve cost approximately $200 after shipping. I think I will opt for just blocking the hose as I am not sure if it is the valve or the controller, or a combination of both that could be the issue.
It makes no difference. Just asking why. The "controller" is the Dash AC/Heat panel. It rarely(never) fails. IF the valve is seeping, you can remove it and flush it out and that sometimes removes the debris that is causing it to not close completely. Doug- mc_ccExplorer
Ivylog wrote:
Spend your money on a manual valve somewhere in the system to stop the hot water from circulating. Close it in the summer and open it in the winter.
Sounds like a good idea in general, even if there is not a problem at all. Thanks for the advice. Will do. - mc_ccExplorer
Thanks Doug! Which is the inlet hose? On the valve there is an arrow that I think indicates which way the coolant is flowing. I blocked the hose as it exits the valve going to the core. There is an upper hose connected to the core that I think is going back to the engine. This is the hose that I was referring to when I asked if I could potentially block both hoses. A new electronic valve cost approximately $200 after shipping. I think I will opt for just blocking the hose as I am not sure if it is the valve or the controller, or a combination of both that could be the issue. - IvylogExplorer IIISpend your money on a manual valve somewhere in the system to stop the hot water from circulating. Close it in the summer and open it in the winter.
NO, it will not create any problems. Think about it. What happens when the water valve functions correctly? It blocks the water flow off completely. Why did you not block the inlet hose first,instead ???? Doug- flapbreakerExplorer
Couldn't tell you if it's harmful. Does it look like this one?
http://www.thermotion.com/pdf/4_Port_Data_Sheet.pdf - mc_ccExplorerI have discovered that I am having a problem with the electronic water valve on mine. It is a two hose system. I blocked the hose that exits from the valve going to the heater core with a pair of vice grips. It works and I am getting cold air now. If I block the upper hose to the heater core too, will this create pressure in the heater core causing potential problems, or is it OK to do this?
marcsbigfoot20b27 wrote:
The only correct way to diagnose an AC system is to throw some gauges on it. R12 or 134a ?
It is 134a. Doug
38,736 PostsLatest Activity: Jan 14, 2015
