Tom_Barb
May 08, 2013Explorer
Manufacture a connector cable by using the parts from NAPA, a 6' length of 4 wire cable a 4 pin female connector, and a female 7 pin connector to fit the RV..
the silver pin in the 4 pole connector is ground to the RV ground pole.
the brass pin directly across from the silver pin is parking lights, the other 2 are L/H and R/H brake and signal lights. as wired in your Toad.
this shows the 7 pin connectors
7 pin wire diagram for trailerhttp://vimeo.com/39205694
This may also help
http://www.etrailer.com/question-27196.html
This may also help
38,766 PostsLatest Activity: Jan 10, 2026
