heyobie
Aug 24, 2017Explorer
I am aware that there was a two tank setup and it works as you described.
Since this post I have learned that all the parts are available to do it. It is just a little more pricey and complicated than I want to get into to duplicate.
So I just ordered the 2nd tank, pump and support brackets. It is a 22 gallan tank which will give me another 150 miles and insurance.
What I'm going to do is just put a switch at the dashboard to turn the second pump on and pump it into the primary tank when I want more fuel
What I don't know is whether it will siphon across by itself. If it does I don't see a problem and it will just make it a larger tank but we'll see thank you guys for your help I'll report back once I get it working
38,774 PostsLatest Activity: Apr 26, 2026
