Dachristianman
Apr 27, 2014Explorer
I have a 92 Brave and my coax cable has long rusted away. I'm not sure how moisture got inside, but the center solid core is gone. I'm sure yours is the same way.
If you can find a good connection inside, I would just tap into it with a splitter and run the cable out the window. You could easily run it under the bench seat and install a hook-up next to your radio. It would be pretty simple to do and it would be a permanent solution.
Tom
Tom
38,766 PostsLatest Activity: Jan 10, 2026
