moisheh
Feb 18, 2016Explorer
Does your HR have that swing arm on the top of the door? If so check to see that it is not loose. This will prevent the top of the door from closing properly. If that is OK you can adjust the post on the jamb that engages the door catches. If you push inward on the top of the door when closed does it move?
Moisheh
Moisheh
38,776 PostsLatest Activity: May 15, 2026
