Thunder_Mountai
Dec 31, 2013Explorer II
This is a common problem with HR/Monaco units. Our 2007 Endeavor leaked around the door for years. Water runs down the side of the unit. Surface tension of the water and gravity will allow water to run around the top edge of the trim onto the top of the door and drip inside.
Looked at what other manufacturers did around the top of their doors. Bought the flexible gutter material with adhesive backing and applied it around the top of the door in an arch to channel the water around the door. Problem finally fixed
38,782 PostsLatest Activity: Sep 02, 2026
