judelaurenzo25g
Mar 30, 2014Explorer
GrumpyandGrandma wrote:Tom_M wrote:
On my 2005 Ford E450 RV chassis the parking brake is a drum on the back of the transmission. Make sure the lever on the drum is moving when you engage the parking brake. If it does not move, the cable is most likely rusted. If it moves and the brake pedal is not to the floor, you may need brake shoes. The cable at the drum is adjustable.
Same on the 08, it has 4 wheel disc brakes
My manufacturer sticker on the cutaway says 08. I do have 4wheel disc brakes and but no drum behind the transmission. The parking brake cables goes to the brake assembly on the rear wheels. Any suggestions on adjusting or do I need to replace the rear brakes?
38,769 PostsLatest Activity: Apr 04, 2026
