Old-Biscuit
Sep 16, 2015Explorer III
IIRC the thermistor should be on 10th fin from right
That moving of thermistor on Dometics is for those models that have a factory pre-set thermostat ......non-adjustable.
With adjustable temp controls thermistor are 'fixed' position on specific fin to give feed back on fin temp (fin temp 10*f lower than compartment temp)4
What fin is your thermistor on?
Fans running in outside compartment?
Freezer temp is a bit high (5* to 8* ------ S/B 0* to 5*) That shows cooling unit is NOT performing as well as it should.
Food section fins frosting up.........door seals or warm air coming back up drain hose.
Maybe install a circulating fan in food compartment.
Check for any obstructions that would disrupt draft.
And if Winnebago didn't follow Norcold's installation CLEARANCES & use of baffles then air flow across back is not correct.
RV IS Level...correct?
Installation Manual
Installation Manual
