rumrunnerxx
May 07, 2013Explorer
If you know which way to loosen and tighten bolts then you can do the sway bar mod yourself. I did mine on the weekend while my son was visiting and the two of us did it in about an hour each working on our own side. If you have the correct tools under there it goes really fast. I spent more time getting and looking for tools than doing the adjustment. After we finished we went for a ride and I was amazed at the difference. The MH corners much better due to reduced sway. I haven't been out in the wind yet but suspect we'll see an improvement there too. Mine is a 30 foot 2003 F53 chassis and I did the front and back sway bars. The front went very quickly with only two bolts to undo. The back took a bit longer as there are two bolts per side and we had some rust to contend with. I would suggest as others have said to go to IRV2.com and search for CHF (cheap handling fix) and do some reading. You too will become convinced that you can and should do it. Best money I never spent! They even have some pictures of some different setups depending on what year chassis you have. Good luck and let us know how you make out.
38,782 PostsLatest Activity: Sep 10, 2026
