spotrotExplorerJul 23, 2013Advice on installing Eternabond 4" strips?About 30% of the seam has separated between the extruded aluminum gutter and the flimsy fiberglass roof material on my 08 Itasca 30B. Last year, I recalked several feet of the same seam using Geoce...Show More
SnomasExplorerJul 23, 2013When you come to 90* corners just overlap straight lines @ the corner. A clean dry surface is a must and it will seal the joint for years.
Related ContentInverter installRemoving Eternabond residueTruck Camper A/C instalationEternabond prep and install adviceRemoving Eternabond
