coolmom42's avatar
coolmom42
Explorer II
Sep 14, 2020
Advice on RV "carport"
I am planning to have a concrete pad beside my house enlarged, to make a good parking spot for my 2014 Coachmen 21QB. Then add a metal cover in the same color as the metal roof of the house.
How large does the pad need to be relative to the RV? Rounding up to the next foot, the 21QB is 9' wide, 24' long, and 11' tall. How much extra is enough room to walk around, load up, etc without being cramped? I also need it to be wide enough that the roof easily clears the the corner of the house, which is about 10 feet high.
The metal cover will be oriented with its roof peak perpendicular to the roof peak of the house. Not my first choice, but necessary to get enough height. (My house is a single story ranch.) I will just drive the RV straight into it, and back into the driveway to exit.
Should I size the cover so it's almost abutting the house? Or leave a substantial gap between the house and the cover?
What about gutters on the RV cover? Most of the ones I see don't appear to have any. But we get a lot of rain in TN and I don't want sheets of water pouring off the cover. All but one corner would be easy to add downspouts with extensions. That corner could tie in to the downspout off the roof of the house.
The RV will be facing directly west, and one side to the north. Those are the directions of our worst storms, typically. I'm thinking of closing in the west end of the cover, down far enough that I can just walk under it, which will protect the cabover area. Doing the same on the north side, probably. Does that make sense? The south side will be somewhat sheltered by the house, and the east is not typically a tough weather direction.
Just trying to think this through before I get prices on concrete and the cover. All constructive input is appreciated.
  • Consider a slight slab slope for water runoff. I used 1/4 inch for 45 feet.
  • DrewE's avatar
    DrewE
    Explorer III
    I'd consider 12' about the minimum width. More is nicer, of course; but that's true pretty much no matter how wide you make it. For the height, it's extra convenient to be able to do RV roof maintenance while under the shelter, but that may not be especially practical or look at all in appropriate scale with a ranch house.
    Keep in mind in your planning that you'll have to drive into and out of the shelter. If you can't get aligned perfectly with it before entering and exiting, you'll need some extra space for maneuvering and turning/angling as you go. Twelve feet wide calls for a good bit of precision in parking when it's delineated by support columns rather than painted lines; and all the more so if the space between the supports is actually a few inches less (and the overall external width is 12'). Along those lines, if the approach isn't level, you need some extra height to account for the tilting of the RV as you enter and exit.
    If you think you might ever upgrade to a larger RV, planning ahead on the shelter size is worth considering. The maximum height for a vehicle in the US without an overheight trip permit is 13' 6", so if at all possible I would suggest a shelter that can accommodate that height. Many class A's and fifth wheels are that height, or very nearly so.
  • The one thing I love about my pole shed I park my travel trailer in is to have enough room under the cover to fully unroll the awning for a few days and let it dry out after use. I think that takes about 20’ of width, which you might not have. If there isn’t enough width for the awning I think 12’ would be a nice width...
  • Whatever dimensions you finally determine, make it bigger.
  • Make it wide enough to be able to open the door and still be standing on the concrete with the steps down.
