Gjac
Dec 20, 2016Explorer III
dmchamberlainy wrote:You are not interpreting this quite right. If it is a back in site and it says 35 ft max that is the pad size. You will back in with your 31 ft MH after disconnecting your tow car and you will be fine. You just don't have enough room to pull in and have your car sicking out in the road. With a 31 ft MH you should not have a problem getting into most sites.
I will call the park directly. I am afraid that the length issue is the combination. You can not bring into the campground anything longer than 40 ft combining the RV and the car. My coachman is 31 ft and the car puts it well over 40 ft excluding the tow bar which they include. The only campground which allows larger is full.
